It is currently Fri Aug 15, 2025 1:13 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3  Next
 Post subject: Time for a new Dremel...
PostPosted: Fri Jul 25, 2014 6:12 am
OK.... the 3 Dremels I have are from the early 90's. 1 of them croaked last night, and the last 2 are in bad shape. Also, most of my attachments have been modded so many times through the years they are almost useless. Time to upgrade!
I checked out the Dremel website, and I'm pretty sure I want a 4000 model, but what about all the various kits that are available? I want maximum bang for my buck - plenty of options and versatility all in one fell swoop.
You have favorites? Tell me.
PostPosted: Fri Jul 25, 2014 7:17 am
Favorites? I find it hard to use that word in the same sentence with Dremels. I have tried to find other tools to replace Dremel operations wherever I can. Bosch Colt laminate trimmers and a pneumatic air turbine have reduced my reliance on Dremels for guitar building, but I still use them on lots of repair type of stuff.
PostPosted: Fri Jul 25, 2014 7:49 am
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
I'm going to have to side with Barry on this one. I'm easing Dremels out of my life. I really think there's a better way to run a railroad.
PostPosted: Fri Jul 25, 2014 7:55 am
Proxxon...
PostPosted: Fri Jul 25, 2014 10:48 am
Hi Haans,
Thanks for the heads up on the Proxxon tool. I see that there are a couple of different models, one of which is variable speed. Which do you have experience with and could you comment on why it is superior to the much maligned Dremel?
My Dremel is dying a slow death so I have been looking for a replacement also.
PostPosted: Fri Jul 25, 2014 10:58 am
First name: John "jd"
City: Santa Barbara
Proxxon has much better bearings than the Dremel tools, many of which just use bushings. I have the fixed speed model -I always used the variable speed on full speed. Plus the simpler fixed speed model has less to go wrong. Be sure to buy a collet set if you decide to go with the proxxon. I should also note that the proxxon is much quieter and smoother than the Dremel tools which always feel quite crude to me.
-jd
PostPosted: Fri Jul 25, 2014 11:09 am
Never heard of Proxxon. What are you using, and will Dremel attachments work with it?
PostPosted: Fri Jul 25, 2014 12:04 pm
First name: D
Last Name: S
Chris, I blew up a dremel grinding metal. Turns out,it had a lifetime warranty (in 1980).
I mailed it in a got a new replacement.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Jfurry (Wed Aug 06, 2014 10:39 pm)
PostPosted: Fri Jul 25, 2014 1:26 pm
What would you use it for? I found it was only useable for rosette channels, and I can't wait to replace it for that task with a more powerful laminate trimmer...
PostPosted: Fri Jul 25, 2014 1:51 pm
Much better motor, has a metal lower half and real bearings.
Pretty straightforward mod. Grind out the threads with a small sanding drum, tap in a set screw...
Google it or Bing it or Duck, Duck, Go it...
PostPosted: Fri Jul 25, 2014 4:42 pm
Quote:
Chris, I blew up a dremel grinding metal. Turns out,it had a lifetime warranty (in 1980). I mailed it in a got a new replacement.
Did that several times back in the day.... sometimes they came back repaired, some were replaced. Wonder if they'd still honor the old warranty?
Quote:
Google it or Bing it or Duck, Duck Go it....
I only know one other guy who's heard of Duck, Duck Go.
PostPosted: Fri Jul 25, 2014 7:51 pm
don't get the smaller proxxon, it'll blow up too.
I'm going Foredom when I'm ready to upgrade.
Old growth, shmold growth!
PostPosted: Fri Jul 25, 2014 7:55 pm
I've heard a lot of good things about Foredom flex shaft tools from wood carving friends.http://www.foredom.net/flexshaftkits.aspx
John Hall (Blues Creek Guitars) has air powered tools on his site also.
PostPosted: Fri Jul 25, 2014 11:28 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Problem I found with Foredom tool is that it can be bulky and cumbersome sometimes, especially for quick jobs. Dremel seems to excel at that. That said I think Proxxon is better made because they aren't made in China.
Typhoon Guitars
PostPosted: Sat Jul 26, 2014 8:25 am
Last Name: Killin
Once you put the Foredom motor on a hanger it is anything but bulky and cumbersome. The problem is that sometimes a flexshaft tool isn't the right tool for the task. That is where the Dremel or Proxxon come in.
I love my Foredom for rosettes. I also like that I can buy parts and rebuild the hand pieces if I ever need to.
PostPosted: Sat Jul 26, 2014 10:21 am
The 4000 is much better than the older ones.
PostPosted: Sat Jul 26, 2014 12:49 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Like I said I'm replacing my Dremels. However,I do find it combined with a flexible shaft a very handy tool. Lots of little jobs that it is just right for.
PostPosted: Mon Jul 28, 2014 8:19 am
Anyone have something else to add?
Frankly, I've checked out both websites, and Dremel seems more user friendly.
I dig the ball bearings, over bronze bushings....
Need more from you guys, if you want to convince me.
PostPosted: Mon Jul 28, 2014 10:04 am
First name: Greg
Last Name: B
City: Los Angeles
Just FYI, you guys do realize that brushes are replaceable on Dremels right? They do wear out after a while.
I've still got a couple in my random tool box somewhere, and couldn't even tell you what models I have. IME the new Dremels seem to be better than the old one I had as a kid, as well as the earlier 'modern' screw top Dremels. The older ones, both USA and import, had more play.
PostPosted: Mon Jul 28, 2014 11:04 am
Sure, but that's not the only parts that wear out.
PostPosted: Mon Jul 28, 2014 12:11 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
I still use a Dremel for the rosette. The one I have works fine, just make sure you purchase it from a dealer that will accept returns or exchanges if you're not happy with the unit. The problems with Dremels (and a lot of other things these days) is the level of quality control. The unit I have now was the third exchange due to runout problems with the first two. I figure that 1 out of 3 is probably about average.
I'm looking at proxxon right now, but it seems I would have to order it online which is a hassle if you have any issues with it.
Good luck.
C~
PostPosted: Mon Jul 28, 2014 12:33 pm
"Need more from you guys, if you want to convince me."
We picks our poison and takes our chances.
I appreciate the pointers given in this thread and will do a little bit of research on my own. The odd jobs I use a dremel type tool for don't include rosettes at this time, but using it as a small drill, cutoff tool, sander/grinder & etc. Thanks again to those who posted.
PostPosted: Mon Jul 28, 2014 1:47 pm
tossed the dremel
if you don't have an air compressor the Foredom will do you well. I never used the proxxon but it looks a heck better than a dremel.
PostPosted: Wed Jul 30, 2014 9:03 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
Found this at Frets.com
http://frets.com/FretsPages/Luthier/Too ... mbear.html
PostPosted: Wed Jul 30, 2014 9:56 am
Good stuff! Thanks for the post.
Users browsing this forum: doncaparker, NikolayUsalf and 10 guests
